Hi all, new to this forum as a member but it has helped me out alot without needing to post. This time I'm slightly stumped!
I am fitting a cooker hood and will wire direct into a junction box hidden behind the hoods chimney. It will then be wired horizontal along and then vertical down above a twin socket to keep within routing regulations.
I know this has to be wired into a 3a fcu.
So my question is, could I use a cooker switch with a socket and use a 3a fuse? This way I could just replace the existing twin socket plate instead of having to try and cut out a tidy square in the tiles or put a new 3a fcu in a cupboard.
Hopefully I have worded this correctly and can be understood haha!
Thanks in advance for any input.
