We've got a newly installed BAXI 33 HE A combi that is losing pressure. I'd like to isolate it to check for internal leaks before calling the engineer back out. I'd like advice on the correct procedure. I understand that leaving it isolated overnight should be sufficient.
I presume that I need to turn off the heating flow and heating return?
Do I need to turn off the cold water inlet?
Finally, should the boiler be left on whilst doing this or should it be turned completely off?
Many thanks,
DNM.
Many thanks,
DNM.
