Hi, i have a coupe of question.
1. What sort of external earth block is used for an external MEB, used to connect the MEC and a sub-mains earth on a TNS system?
https://www.tlc-direct.co.uk/Products/TLEB8.html
Is this what i am looking for or am i barking up the wrong tree. Does it need to be fixed inside an enclosure?
2. Does a switch fuse always have to be rated lower than the main cutout? Or can it be equivalent to the main cutout?
For example on a 60a main cut out, does the switchfuse used to supply the sub-mains have to be 60a or less?
