Cover Panel confusion with the Dishwasher
5 Oct 2004
Essex
I've just installed an IKEA METOD kitchen and the granite worktop is about to go next.
I cannot understand how to install an End Cover Panel to a dishwasher that is the in the corner of a (now open ended) wall.
I've been told by Ikea that the cover panel is:
  • Not attached to the dishwasher and rests on floor.
  • Would need to be attached to the floor (had a buy full length of tall cover panel)
  • Would need to buy floor fixings from Screwfix/ Toolstation etc as Ikea don't sell them. Which ones do you recommend?
  • Would also be attached to the worktop (should I leave that to the installers)?
Please check the attached pic and advise on the above points?
I also tried to hold the dishwasher with a flat metal plate as you can see. Should I remove it now as the wall behind it is going to be tiled?
Thanks for your help in advance.
a>
Difficult to see what you have there, but end panel should be secured to rear wall [baton if you have room] and the floor [any suitable bracket should do it] and ideally have a timber panel over the front of the dishwasher so you can attach the dishwasher to the top [stops the dishwasher moving when the door is opened/closed]. Worth speaking to the granite installer to see if your design is substantial enough as a lot of weight on top.
