Help, please! The cork tiles and adhesive are off the bathroom floor which is wood over concrete. The ceramic tiles went down fine, but the grouting is cracking - any ideas? Remove grout and then silicon? Thanks
More info needed...
What type of "wood" is fitted over the concrete?
How is the "wood" secured down?
As mentioned, what adhesive and grout did you use?
What type of tile did you use?
What size of grout gap did you go for?
