curved roof construction
21 Jul 2010
Weymouth, Dorset
I want to create a roof structure for curved corrugated steel roofing sheets. It's going to be around 2.4m wide by 4.8m long.
I was thinking of making up curved rafters out of two pieces of ply with solid wood spacers. Cutting the ply in a curve section by jigsaw and screwing/gluing the spacers in-between.
Then skinning the roof in ply sheet.
So is this entirely feasible and if so, how deep should the ply rafter sections be to give it the strength?
my instinct is to laminate in solid wood and bend it round a curved jig like making deck beams for a boat,probably 5 or 6 inches deep
I would forget the spacers and laminate the ply together, say 4 18mm ply sheets which give a support 72mm wide which will be very strong, in confine spaces or difficult access this method is use to create structural support where a steel would normally be used and is very strong. Depending on the height of curve you could get several from an 8x4 sheet.A curve height of 300mm should suffice.
