cutting 2mm mild steel sheet
30 Dec 2005
Gloucestershire
What is best tool for this smallish diy job ? angle grinder with 1mm or 2mm slitting disc ?
Keith
Jigsaw
jigsaw with correct metal cutting blade and plenty of cutting oil.
Wotan
angle grinder with the 1 or 2 mm disc. You can get in at much better angles.
Whats size steel are you cutting. And how accurate does it need to be?
U could just pop down to your nearest industrial estate im sure ur local metal work firm will cut it on their guille for a drink if its a big sheet.
