Hi.
My house has a number of partition walls that are made using what i think is 35mm stud's and noggins ( probably in the form of a pre-built partitions) in this 1970's terrace house.
I'm looking to cut a door in one of these walls, but don't know what to use as a door liner? Looking at the other doors in the walls they have cut the wall from floor to ceiling and run a piece of 50mm stud down the cut out, built it out with architrave and hung the door off that and put a piece of glass in above to fill the gap.
Are there any better ways of doing this?
Equally, i need to replace some of the studwork elsewhere in the house due to water ingress. I understand that 35mm is definately not normal. Do i need to be aware of anything with 35mm stud?
Thanks!
Thanks!
