Hi
What temp should this be set at?
Reason for question is that my myson apollo pump works ok on high, but switch the high low switch to low and it runs all the time, even if the boiler hasnt fired up.
I think it is currently set at 60.
someone said that the low on the high low switch is lower that this - could this cause the pump to run all the time?
