dab Bug connections?
14 Jun 2009
Essex
Hi purchased a dab radio called a Bug. various plug connections on the back, just wondering if there is a way of connecting external speakers and/or a ipod?
Thanks in advance
Thanks in advance
You could attach external speaks and or an ipod, but you will need to recognise your connections...
you may have an aux port on the back of the unit - it may be an input or output - check your instruction book if youre not sure. If its and input, you could plug the ipod into this. if its an output you can plug speakers into it.
you may have a 'ext speaker' on the back of the unit - you can plug external speakers into this - either a set of powered ones or a lead to an amp
If you have non of the above, you carnt plug and ipod in, unless it has a the unit has a specific ipod dock!
Also, this leave you one option with the speakers - the headphone socket - you will need to attach a lead to an amp or powered speakers!
HTH
Cheers, will take a look at the back once i return from a liqiud lunch :)
