Thanks for your reply, can you have decking on concrete?
also how would I build the frame as the house is one side and a fence the other, so I can't put screws in from the outside, Should I make the frame then lift it in?
yes you can. you can skew nail the joists in place, ie go through the joists at an angle in to the frame, or you can build the frame and then lift it in
