Hi All
Does anyone have any tips for working with Dexion? I've never used it before and need to create some L-shaped benches at a particular height. It's 40mm stuff (so only has one set of holes).
In construction and planning...
- Do I really have to cut to the diamond shaped holes? (ie everything be at 3" intervals)?
- How many bracing plates should I use (must they be on each joint)?
- Space is limited, and I was thinking of doing the left and right ends and then adding the cross pieces in situ. Is there an accepted way of working?
In terms of coverings...
- I was planning to use B&Q worktops for the top surface, but need something less substantial and expensive for other layers: any suggestions?
Any other pointers (like any tips for getting all those bolts done?) appreciated.
Regards
Ben
Regards
Ben
