Digital tv in North west Ireland?
14 Mar 2006
Essex coast
Brother has moved there close to Knock airport, he can't use his UK bought tv there as digital signal is not the same as UK, is that correct, what are options?
Look in the TV's menu to change the country to Ireland. On my Samsung press "menu" on the remote then select "channel" and then "country". From there select "Ireland". Then select "auto tuning" within the "channel" menu.
Brother has moved there close to Knock airport, he can't use his UK bought tv their as digital signal is not the same as UK, is that correct, what are options?
How old is the TV? Ireland uses MPEG 4 for SD channels whereas the UK uses MPEG 2. Newer TVs will handle MPEG 4. Best thing is to try and see, if TV is MPEG 2 only you will get sound but no picture. If this is the case buy a Saorview box, around €40 I think.
