I have a very similar situation but I realise that I need a slave - however the wires I have are very different and as easy as it is for a standard conventional two way switching I can't for the life of me work out how to wire the master or the slave varilights.
at one switch the master I have:
one live feed - red wire in a grey sleeve
one set of strap wires (a red wire, and a black wire with a red sleeve)
at the other switch the slave I have:
one load wire to the light - red wire in a grey sleeve
one set of strap wires from the master (a red wire, and a black wire with a red sleeve)
now I need to chuck the varilight into the equiation...
on each of the varilight switches - master and slave they have three ports - live - S - load
for the master I take it that I put the live (red) into the live
put the strap black with red collar into the - S
put the strap red into the load
on the slave I take it that I put the load (red from the light) to the load
put the strap red into the live
well this I have done and I get no joy :S
any help would be great - at the moment so I have light I have just connection blocked the live to a strap wire and am running the master as a single light switch with the live and load connected.
