Why is it that when my lounge dimmer on 2 way lighting is on and when I put a neon tester on the earth it lights up but does not give any shock.This includes the back box even with the earth disconnected from the switch.Is there a fault
Yes, possible down to the equipment you are using to test with, neon tester cannot be relied on, when testing for voltage always use an approved two pole/probed voltage indicator. Bin the neon!Is there a fault
Yes - unless any double pole switches are open.Should there be continurity between newtral and earth
No, unless one of them touches earth.You cant blow things by conning 2 way lights wrong can you as there are no newtrals.
