i've installed 6 12v 25w halogen downlighters in my study, each of them with their own transformer.
They all work perfectly well when using a normal switch.
I decided to replace the switch with a dimmer and again all fine.
the only problem is when I dim them to the lowest setting on the dimmer, the lights only dim to about half their full brightness and the dimmer switch emits quite a buzzing- I've tried different dimmer switches and get the same result?
I would like to dim them fairly low if possible to avoid glare on the PC screen.
Any idea's?
Any idea's?
