I live in a block of flats built new about 7 years ago. Unvented system, gas boiler (Potterton I think).
There are 3 flats, one above each other, and copper discharge pipes come out at each level, join a common downpipe, and terminate just above the ground at the bottom. From looking at the outside of the block, as far as we can tell, only our 3 flats are joined to this particular common downpipe.
There does not appear to be any pattern to the timing of the discharge, but when it does come, there are pretty steady drips (enough to form a pool of water outside my garage!)
2 of us in the 3 flats have checked the visual overflow/tundish thing in our systems when the dripping has been going, and apart from a little condensation moisture, there is not nearly enough to cause the level of water coming out outside. The third flat kindly shut their boiler off, ran their tank dry, and the drips were still coming out.
There doesn't seem to be anything coming out of our systems from looking at the visual thing, so I am stumped.
Any possible ideas?
Any possible ideas?
