Are you hard of thinking? We are talking stop ends, you are not professional if you use push fit as a permanent solution and there is no argument about that.
Alrite Gav, just having a wee laugh reading through all the replies which must have left the OP scratching his head. Compression fittings, solder caps, flattened pipes. Even a wee debate to what is most appropriate.
Don`t ever use pushfit fittings, ever,don`t ever use compression fittings ever, pushfit will definitely eventually fail, not all but some, compression or conex fittings,for the Numpty who says they never fail,always fail if they are fitted in a low or freezing temperature because the cold water expands and pulls the pipes out from the olive. Copper pipes everywhere and soldered fittings ALWAYS! Unless of course all joints are fully accessible and easy to repair/replace.NEVER, EVER! fit a pushfit or compression fitting under a floor, in a wall or void that you can not get to once fitted. EVER! Point made.
