Does a flexible WC pan connector fit directly inside a ring seal and/or solvent weld fitting?
1 Jul 2016
Hi, please forgive the newbie question:
Will a standard McAlpine Flexible WC Pan connector like this...
... fit directly into a ring seal connector....
and/or a solvent weld connector....
...on a standard 110mm soil pipe? Or would I need to insert a cut piece of pipe inside each of these first, so it fits inside the 110mm pipe without a connector?
Which would give the most secure fitting?
@Dan Robinson Thanks, so you can't put the flex pan connector into a ring-seal fitting, like this chap suggests?:
It just has to go straight into 110m pipe itself?
