does copper pipe come in 25 mm?
27 Dec 2006
London
I want to make a kind of built in corner wardrobe and was planning on using 25 mm dowel and a couple of 'wardrobe rail ends', creating a right angle by glueing the dowel into a copper 90 degree elbow . . . .but I can't seem to find any 25mm copper fittings . . . do they exist?
cheers
No.
22mm or 28mm OD copper.
Or use a brass/iron f&f 1" bsp elbow and you could screw the dowels in?!
You could drill holes through a block of wood and carry one dowel on to the wall/end, making a T, which would support the rails too.
Trim the dowel to fit into 22 mm fitting. :idea:
Look a bit naff though.
Why not use the proper rail hangers :?:
its in a corner of the room, and I want to maximise hanging space so thought I'd come out the wall 500mm or so, then 90 degrees and back into the other wall, with a T used to run a dowel down to the floor for support . . . .
cheers
mmmmm, see what you mean :)
can't quite picture the wood solution though I think you're onto something . . . I could start with a block, drill holes in 3 sides to take my 3 dowels, then shape the wood so it doesn't look toooooo crap . . .
buy 28mm ext diam pipe, it is very near an inch inside
johnd, that won't work with the "rail ends" which as far as I know will only take inch . . . .
