D
Deleted member 18243
I've been reading that door closers fitted with parallel arms are less efficient than those with standard arms.
Is a door closer specifically made to be fitted with one type of arm, or can you change to a different type of arm on a closer?
I ask because I have a door with a parallel arm closer and it has never been satisfactory. Would fitting a standard arm improve it, assuming there were no other problems with the door?
Thanks.
Thanks.
