Door Entry Handset Replacement wiring problem
6 May 2020
Denmark
I have replaced my old door intercom handset. I live in a block of flats which use phones with buttons to open the main door or visitors. The old handset is a Comelit Vox 2000 and I have bought a replacement Urmet 1133/15. I have attached a list of comparable wiring diagrams given by Urmet. The problem is that visitors can not hear my voice when I use the handset. I can hear the visitors and the buzzer also works fine when opening the door. I have also tried to adjust the mic and speaker dials on the new system without any resolution.
I have attached a few pics of the old intercom and a few pics of the new so you can see the wiring. Would appreciate any suggestions as to solve this. Many thanks.
Comelit Vox 2000 : http://www.intercomsrus.com/handset pdf/Comelit Vox 2000 Intercom Handset Data Sheet.pdf
Urmet 1133/15 : https://safelink.co.uk/wp-content/uploads/2015/07/1133_15_conversion-chart.pdf
the Comelit Vox 2000 was an old and existing installation that used to work. It recently had noisy (noise from the speaker i the handset). there is also a red button on the handset you have to press in order to speak. In the Urmet 1133/15 there is not a a similar button when you have to speak.
Would have gone for a comelit 2603 universal handset ....where are you based ?
I am based in denmark - do you have any suggestions as to how i can solve the issue ad hand?
