Hi there,
I'm currently opening up the fireplace in our 1890s terrace to put in a reclaimed old cast iron fireplace. All well and good, but the cast iron insert is too tall to fit in the builders opening as it stands. Even if I were to remove the 3" hearth, it'd still be a shade too tall.
The fireplace is supported by a brick arch consisting of two rows of half-size bricks - see image. If I were to remove the lower arch, the insert would fit.
The alternative seems to remove the arch entirely and replace it with a concrete lintel at the level of the upper arch.
Grateful for some advice as to whether I can safely remove the lower arch and rely on the upper arch to support the masonry above, or whether it would be better to replace the arch altogether with a proper lintel.
Also, I need to remove the existing fire back (in picture) and reset it deeper into the recess. What's the safest way of unseating it without causing it damage?
Cheers,
Matt
Cheers,
Matt
