Hi I have a double oven with a power rating of 6.0KW (nominal power) and a total consumption of 2.6KWh and a Electric 5 ring hob with a rating of 8.6KW (nominal).
= Total or 14.6KW
What is the best way of wiring these in. I only have space on my consumer unit for 1 more breaker. Is there a way I can run these on the same breaker (maybe a 45amp)
What rated breaker should I use??
What cable do you recommend (6mm2 maybe)??
Can I get a junction box to split the power??
After the split can I use 4mm2 cable??
Any advice??
M
= Total or 14.6KW
Any advice??
M
