Kitchen is all stripped out so i can do what is ness.
oven 5kw hob 5.8kw
Distance from CU to CCU will be 9m ( from CU,clipped along ceiling joist and then chased down wall to CU
Now then,i really only want to run just 1 cable from CU to feed both the oven and hob.
So my questions are:
Can i run just 1 cable and which size 6mm or 10mm?
Which breaker?
How do i wire 2 outlets to 1 CCU?
Which size cable from each unit to the outlets?
Be grateful for any advis
oven 5kw hob 5.8kw
Which breaker?
