Hope someone can help. I currently have a radiator on one side of the room which I want to move to make way for a new kitchen table. The easiest place for me to move the radiator is to below a double socket which is located half way up the wall (a hang over from where there used to be work surface with sockets running along the wall 150mm above it).
The socket will be 260mm above the top of the radiator. Is this allowable or is there some reg which states minimum distance sockets should be from a radiator.
Thanks.
srj321
Thanks.
srj321
