Hello,
i use my garage alot for my work and things, and in the winter its F R E E Z I N G. i am willing to put electric heaters in it, but im not prepared to do that if half the headed air will escape out the gaps around the garage door. i have sealed the side entry door (literally, i screwed the door into the frame)and the door into the house has normal strip excluder around the frame.
the big metal up n' over door has a half inch gap all the way round... i have tried putting rubber lips on the door frame so that it seals the door. worked well BUT the door would not open very easily as the door gets jammed on the seal. i cant seal the bottom because the metal bit at the bottom is too short to attach anything too...
all i can think off is hanging a bit curtain from the wooden beam at the top and hang it down over the door compleatly...
any thoughts or wisdom greatly recieved.
Thanks,
Pete
Thanks,
Pete
