Hi all
I am installing an en-suite in my new dormer extension and need advise on drainage.
The property is a bungalow and does not have a soil stack. The toilet, sink and bath waste in the original bathroom all connect via a 4" pipe in the space under the floor boards and then head directly outside to the main drainage (no vents).
The plans for the dormer show an orrible new stack attached to the gable which extends up passed dormer roof level. This is a major headache as the drive is block paved and I'd rather not excavate to expose and connect into the old drainage system.
The easiest solution would be to install an internal stack which can extend vertically up from the dormer bathroom through the remaining section of the pitched roof and vertically down from to the ground floor bathroom directly below (which can be run through a conveniently positioned airing cupboard) through the floor to connect to the existing drainage.
Does an internal stack sound feasible and is the building inspector likely to go for it ?
thanks
Mick
thanks
Mick
