draing down a microbore ch system
1 Feb 2005
I want to alter pipework- 8mm- to replace old with new radiator upstairs . System has manifolds upstairs & down - under floors. Do I drain system as normal i.e. open drain cock at lowest point etc .Can I part drain ?. CH is about 20 yrs old. has both 8 & 10 mm pipework .
Also when hot water only is on , upstairs radiators get warm/hot.
Thanks for that . Can I part drain ? i.e. just drain enough water out until the pipe I want to work on is empty ?.
Kevplumb your a star , what do you think about the rads getting warm when only the water is on. I have the ch system with a big & small tank in the loft , the cylinder is the type with the coil inside from the ch .
Kevplumb I,m sure its gravity - there are no valves anywhere on the system .
