- Joined
- 27 Apr 2008
- Messages
- 9,479
- Reaction score
- 899
- Country
you can get away with a decent masonry bit. You will however, need to build a small plasticine wall around the point you want to make the hole and fill it with water (so obviously this only works on floors). You then drill your hole (on a slow speed). It will take a while, but it will go through eventually.
Remembering to turn the "hammer" action OFF
I did this on many occasions before I discovered tile bits.
I still do when the cheap naff tile bit has broken & i'm 1/2 way through the hole
