Hello,
following some previous good advice here I am having a go at fitting an outside tap on a timber framed house wall.
I have made a small exploratory hole on the inside where I am looking for the pipe to go through. Gently feeding a thin probe into this hole it goes through to a depth of 105mm, so it looks as though I have thankfully missed any studwork.
As the wall is 270mm thick and with the brickwork accounting for 100mm I am guessing that the remaining 65mm is the plywood outer sheathing and then the cavity? Does that seem about right?
I have restricted space on the inside, enough for the plumbing work but not enough to get a drill in. Is it OK to do all the drilling from the outside, with a thick masonary drill through the brickwork and then switching to a long wood drill to go through the plywood sheathing?
