drilling set angle through newel posts?
27 Dec 2006
London
and for another question! I need to drill fixed angle holes through two newell posts - am installing balustrade wiring in place of spindles, any tips on how to build a jig or hold the drill in place? The posts are 4 by 4's.
cheers
Huey
Try this or if you want to spend some dosh, this:
Scrit
Just a thought :D
I was looking for pocket hole jig and was talking to an engineer friend who made me a jig out of metal just with an angle drilled through works a treat and no need for longer or special drill bits ect
admittedly it,s only been used for cabinet making ect but gives perfect results every time :eek:
hope this might help
Martin
thanks guys, I tackled the job yesterday (with rather a stonking hangover I should add!) - used big-al's suggested method - cut a peice of wood to angle using mitre saw, then drilled a hole using drill press. some accurate marking out and then drilled into the posts from either side using a 4mm bit - - ALMOST got it right . . . looked a bit of a mess but once some paint had been applied its not too bad ,.. . .
thanks once again for help.
Huey
