Having seen the red dust around the edge of the ground floor carpet, I suspected dry rot was the culprit so pulled up the carpet to see rotten floor boards in the corner of the room. Pulled up a load of floor boards and yep, the ends of several joists are all rotten and the ground below the joists is coverd in a creeping pale coloured mushroom like substance.
So my plan is to cut back all the joists 500mm beyond the worst bits and replace with new timber. Then shovel out all the cr*p from under the joists and scrape it off the walls around there and then spray the walls and ground with a dry rot treatment.
Does this sound right ? What treatment/product would you advise ? Cuprinol Dry Rot ? Do I have to inject it into the bricks around the joists where the mushroom stuff was attached also or just spray them ?
I had thought of wrapping the ends of the new joists with DPM before fitting them into the walls or is it easier / better to use metal joist hangers ?
There is a small wall across the middle of the room to support the joists and the only air brick is on the side of the wall that has no rotten timber and only a small amount of reddish dust. on the ground. So I am thinking of adding a 2nd air brick on the side of the wall where all the mushroom stuff was on the basis that that side of the floor is lacking air movement and maybe that's why I have got the dry rot ?
Would you also spray the treatment stuff on the floor/wall area on the side of the supporting wall which is not as affected ? or is that a waste of time ?
