I was working on a circuit today which was fed in 2.5mm² SWA cable buried aruond the perimiter of the building with a circuit length of approximatly 150 meters. The protection device was a 16A type 'C' MCB. The Zs value for the circuit was 3.14Ω which is above the permitted value for the type and rating for the MCB, so we had to replace the MCB for a 10A type 'B' MCB. My question is: Had the circuit current or circuit Zs been higher making it not possible to fit the 10A type 'B' would it have been permissable to install an earth rod at the end of the circuit to reduce the circuit Zs or does this cause problems by introducing an additional potential into the installation and also possibly having two Zs values on the same circuit? This is just to cure my curiosity (again)
Rob
Rob
