Red tail from the left of the cutout looks to feed straight into the henley below the meter, which supplies the bottom fusebox.
Thats the only pic i got at the mo, as im not living there. Yes it is overhead power supply.
Complete re-wire, new CU, all updated,etc is on the list of things to do, just getting round to it.
Getting drive done, then a interal wall being knocked down, then its electric's or plumbing!
I am thinking it is unlikely that you can have an earth supplied from your electric board hence find out exactly what this person is wanting to do. Like I said before only the electric board can install a terminal to allow you to connect an earth to their system, might not be available as you are on an over head system. My first thoughts are you will probably find you will need to remain with a TT system where the earth is supplied by the earth electrode.
You could do with an overhaul of the consumer units tho, like I said the VO ELCB should be replaced.
Is it burried directly in the ground?
