I have replaced my gravity fed shower by a new shower cubicle and a Easiboost 2 shower pump. As I live in a bungalow the original gravity fed pressure was quite low and the intention was to boost the pressure and flow rate accodingly with the 2 bar pump.
Following the manufacturers recommendations I have installed the cold and hot supplies directly from the cold tank and from the hot cylinder (essex flange). The pump is installed 3 metres directly below the tanks in a floor space (under the ground floor) , from the pump the route then goes horizontally for about 6 metres then up 1.5 metres to the shower head through a mixer. All routes incorporate sweeping bends and as instructed, all piping is 15mm apart from the 15/22mm reducers at tanks. The hot water cylinder thermostat has been turned down to 60oC.
The pump operates but the flow is no different to that of the old shower.
I would be grateful for any advice or help.
