Recently bought house, had new central heating previous, Combi Boiler upstairs cupboard, 8 radiators, 7 with Thermostatic Radiator Valves but it seems dodgy plumber didnt fit a wall thermostat to finalise the installation correctly.
Have had a look at the boiler manual (Boiler - Ideal Mini C28), shows how to dismantle the boiler and locate the "External controls terminal block" - has three individual connectors described as 1,2 & 3! which is described and shown as under the "Power Supply" terminal block.
I want to fit a wall mounted thermostat in the hall directly under the boiler location so running wire down internal stud wall is not a problem.
I have looked at a downloaded installation PDF file for a Thermostat sold on Screwfix - "Danfoss RMT230 Room Thermostat" Item 22657.
Q1 - Am I looking at the right type of thermostat
Q2 - PDF file makes no sense to me how it wires up, is it 3 flex wire simply between Boiler and Thermostat and running off boilers elec supply, does it need seperate fuse etc????
I am totally lost on this so if anyone can help I would be very grateful...
