If you remove the lamp, I bet the LED will go off
If I remove all four bulbs the LED does indeed go out.
I found an old analogue multi-meter (with a low battery). With the bulbs out, and the LED off, I put the black probe on the switched live side of the light switch. With the red probe not touching anything, it read 20v.
When the red probe was attached to the live side, the reading dropped to zero.
Does this indicate that the shock that I got was down to induction and was only 20v? I guess that if the switch were pumping 20v through the circuit the multi-meter wouldn't have dropped to zero when both probes are used.
As I mentioned in an earlier post the effect seemed to be localised in my hand and arm and no further. TBH I didn't think that 20v on a lighting circuit would have been noticeable. Am starting to feel like a bit of a wimp now for complaining about the shock ''
If all of the above is indeed down to induction and not the fault of the switch, short of a full rewire is there anything that I can do?
