ban-all-sheds said:How do you know he's not got a combi?Pensdown said:Not sure if you have done the plumbing yet but a tip from friend was to plumb the towel rail into the hot water circuit and not the heating. That way in the summer, the rail is still hot. If you break in before the control valve it will run on your hot water time control and not the tank stat
Quite correct. It may have been better if I had typed:
"Not sure if you have done the plumbing yet but a tip from friend was if you have not got a combi system,you could plumb the towel rail into the hot water circuit and not the heating. That way in the summer, the rail is still hot.
And here, rather than adopt the negative "Jeremy Paxman" approach, you could have taken a more helpful and positive approach and typed;How do you know he's not got a combi
This is OK if you have not got Combi system.
Although I have expertise in some areas of the electrical industry, I like a lot of others on here are always learning (which is why I joined). It is essential that the advice given in these forums is policed and is correct, however, when a reply is only slightly wrong or another scenario has been missed, I feel the positive approach may give a better impression of what the site has to offer rather than a negative one.
I love reading some of the reply's posted on here but i'm sure some are only intended to bring out the worst in people
[/quote]
