Electric heated towel rail BTU rating vs CH heated rating
13 Mar 2007
Kent
A friend is having an electric element heated ladder style chrome towel rail fitted in a bathroom ( by and electrician). This will be the only source of heating in the room.
I have always had CH heated rads so wonder how the quoted BTU rating of a given sized rad varies up or down if heated by an 300w or 600w element.
Surely the rad mustn't exceed a given surface temperature to avoid scalding.
any replies welcome.
CJ
The towel rail should also have a BTU rating as well as a wattage. This allows you to compare like for like. There would never be an overheating problem.
thanks but my question is .. a rad will have a given BTU/wattage rating if run on a CH system at eg 160deg F.
So if the same rad is heated by an element, either 300w or 600w, will the rad give the same heat output at a safe surface temperature ?
No, you miss the point, so let's try and break it down, because I'm afraid that you're asking the wrong sort of question.
A towel rail with an element will never have an element in it that would allow it to reach an unsafe surface temperature.
There has to be a common reference point, and that's measuring the rad (either water heated, or electric heated) in BTU's. A plumber would measure the size of the room, and then take into account whether it's got solid walls, insulated or however it's constructed, and they'd then calculate the number of BTU's required to heat the room. But towel rails were never designed to heat a room, (unless it's quite small) they were designed to warm up the towels, and having a heating element in them, they could do it all year round, not just when the heating was on.
A central heating rad will be running at about 75C, and a towel rail with an element in it will end up with about the same surface temperature, but a larger towel rail, with a larger heating element will be able to heat a bigger room. You're not going to be in a situation where you get a towel rail that was designed to take a 300w element, then having a 600w element in it, as this would definitely overheat the rail. A 600w towel rail, will be a bigger size than a 300w rail, so there shouldn't be a problem.
You're friend has to work out what size rail/element/BTU that he wants, either to heat the room, or just warm the towels.
Hope this way of explaining it helps
