I need some help please (electricity is a weak spot)
We have a Ef6400ss proline oven which has been working fine for over 2 years until last week, the Fan element blew leaving cold air flowing only.
I went brave and replaced the element with a brand new one, seemed easy enough. whilst the oven was in bits i plugged the oven in, lights came on and the oven works too (yer sorted) Not
when i assembled the tin covers and placed the oven back in the unit, now the little monkey keeps blowing the fuse. The time led comes on but as soon as the oven is switched on the fuse blows.
I dismantled the oven again and checked for loose wires etc but all seems ok. I tried a diffeernt plug socket which worked for approximately 3 seconds then blew (ahrrrrr) head banging against brick wall.
I've gone through 5 13amp fuses and my wife is moaning cause the kettle don't work etc (lol) I'm a bit dubious about the oven anyway because its
plugged into what appears to be a standard wall socket behind the oven
and the wires on the oven were a bit of a squeeze to get in the plug.
The oven is 2100 watt at 230 volt supply
Can anyone help please
