- Joined
- 26 Aug 2016
- Messages
- 6,833
- Reaction score
- 1,010
- Country
So that's probably added about 0.3 ohms to the loop thus possibly halfing the current. Although even with 1.2 ohm total it should still trip a b40, and I assume your ring is on a b32.
Not conclusive but my money's still on the toilet. Is the heating element removable? Did you check it when you dismantled it? Does the dimming happen when it's heating or pumping? What happens if you disconnect the pump/heating element as applicable and run it (safety first - make sure the unplugged cables are unable to touch anything and wrapped with insulating tape, and the unit is closed up)
