- Joined
- 27 Jan 2008
- Messages
- 23,948
- Reaction score
- 2,717
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
The idea is turn the dial on Nest or set a schedule or use Phone or PC and the four Energenie heads should auto match new setting.
Using the phone with the Energenie software and the heads follow, but any of the other methods and the TRV heads remain at the old setting.
If I view the Nest temperature with the Phone, not try to change, just view, and all the TRV heads follow Nest as they should, and PC software shows they have changed to new temperature, but with PC Energenie head don't auto follow, and with scheduled change they don't follow.
I can unfollow Nest and set the TRV heads to change at the same time as Nest, but then if anyone turns the Nest thermostat up manually the boiler will run but rooms will not heat up.
I some times get error server not responding please try again.
Until I have worked out the problem I have unfollowed and set TRV heads same as Nest as if Nest runs without TRV opening it could cause pump to cavitate, boiler OK that will still heat domestic hot water, but could damage pump.
