I have an inherited EUROSEC CP8L.
Am redecorating and need to relocate /replace some sensors. I'm able to run new alarm cable although curious how to do connect it without setting the alarm off. I do have the installer code and the user code.
My only experience so far was when we moved in - there was a power cut and the alarm went off. Have since replaced the battery.
So:
Does the C8PL have any anti tamper alarm on the PIR sensors? Is there a procedure I need to follow to disconnect / relocate a sensor?
Do I need to power it down first? When there's no mains power, and, the battery is removed, the alarm goes off. I dont have easy access to the bell box...
Thank you
So:
Thank you
