B
BigBurner
even if you were to replace the standard vessel i'd add an external one as well because the expansion vessel, due to the hot water store, is ridiculously small and if you have an average house with 8 rads (i know you have 7) you need an additional one, if you have less rads but they're big then you also need one.
if you can get away with fitting the external vessel i'd do that.
Bed advice. You size it up and add if need be. If a needless expansion vessel was fitted that would take much expansion and reduce the store heat in the thermal store/expansion vessel.
Depending on the internal layout you may want to put in a second PRV in case.
why? the standard pressure relief will still work
You missed the point.
