I bought a clipsall two gang external socket with built in RCD and have one question I was hoping you could help with - there is no terminal in the socket for the earth - where does that go?
There will be an earth terminal, though I can't advise where it will be. If the connections are made to the RCD part then that may only have Live and Neutral connections, but the back of the socket will have an earth - it may be that there is a cover over it that has to be taken off?
Did you get any wiring instructions with it? I found some technical drawings here but they don't seem to have that exact model.
