I'm weighing up adding some extra studs in my timber construction garden office to help stabilise the plasterboard verses the thermal bridging that will cost me.
At present I have (from outside)
I spaced my framework studs as wide as I could so that I could take full advantage of the insulation and in places the separation is up to 1200mm centres.
My celotex is lovely and flush with the framework, so I guess I won't get much bowing of the PB if any as it's in contact throughout.
I happen to have half a bucket of contact adhesive from installing the EPDM roof membrane (that was a JOY to put on BTW!)![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I wonder if a liberal slap / dab of that both sides of the celotex (on the foil not the PIR, I guess the glue will melt the foam?) will help to stabilise things.
Any thoughts?
Project is coming along a TREAT, photos to the forum shortly when I get a chance to breathe.
- 20mm british cedar cladding
25mm treated battens to hold cladding
vapour membrane
18mm OSB
{70mm studs+ 65mm foil backed celotex}
Any thoughts?
