- Joined
- 12 Feb 2003
- Messages
- 4
- Reaction score
- 0
- Country
I am running three 50W bulbs from a suitable transformer that only has two output terminals. Can I run the cable from one light fitting to the other or do I need to use junction boxes to split the load. If not, sounds like I need a different transformer with sufficient output terminals to run cable to each light fitting individually. If this is the case and my cable length is 3 metres max do I need to uprate the cable from 1.00mm or 1.5mm to something higher and can I use a combination depending on the fittng's distance from the transformer?
