Hi All,
I've done a bit of digging and have found that the fault code is drain fault. I just wondered if it is simply the pump or whether it is the PCB board - just hoping there is a sequence of checks.
It stops when it should drain and flashes 11 times with the dial clicking around, we turn it off and by the end of the day gravity has drained it. At this point we set it to spin and it does a short spin and the clothes come out dry (ish. )
I'm just wondering if the PCB is missing the drain mode or if the pump has definitely gone.
Cheers for any help.
Mark.
Mark.
