Hi all!!
I'm in the process of putting together a fake chimney breast to house extractor fan above cooker... seemed pretty straightforward until mrs said she wants worktop clear meaning it needs to be supported from wall - i intend on using 38 x 63 stud timber and would really appreciate advice on...
what screws to use to safely secured to wall?
whats best way to screw into ceiling nt knowing where joist is?
also thought aboout using these brackets and frame in so not visible when plastered:
http://www.screwfix.com/p/heavy-duty-bracket-black-300-x-300mm-pack-of-2/78941
Total dimensions will be from ceiling down 120cm (to bring in line with bottom of wall cabinet on side with 70cm clearance above cooker at front), 125cm wide and 40cm depth.
Here's a drawing i done in paint in case above doesn't make sense - many thanks for any advice
